obd1 del sol engine harness
Old Dec 22, 2012 | 08:59 AM
gzes's Avatar
Default obd1 del sol engine harness
Ok ive looked aeound but havnt found the answer. I need the part of the harness that connects to the injectors and engine and trans. Its a 94 del sol b16 so if i get the harness from an obd1 integra it would plug up and work? If not then i have to order it from ebay or drive 2drs amd get one... thanks
Old Dec 22, 2012 | 06:11 PM
gzes's Avatar
Default Re: obd1 del sol engine harness
Bump
Old Dec 22, 2012 | 06:26 PM
hyperEG1's Avatar
any obd1 vtec harness will work. eg/ej, dc2, del sol si, del sol vtec all have the same engine harness.
Old Dec 22, 2012 | 07:27 PM
crx_si-r's Avatar
not all the harnesses are the same. as long as motors are the same, then they match up.
93 DX harness will not be fully compatible with a 95 EX. vtec will not work unless its added in to the harness. all 92 model civics were pre wired (chassis harness) for vtec so this year is an exception.
and GSR engine harnesses will be wired for knock sesnor where as the civics did not have them
Old Dec 23, 2012 | 05:08 AM
gzes's Avatar
So they will hook up to the sol harness? My engine harness from the del sol is tashed... The po cut off the injector connectors and ripped up the harness itself cutting different places bit i got all the other harnesses for it and just need the engine one. I believe there still moght be 2 integras in the yard i go to so would one fit i gotta see what year but i think they are pre obd2
Old Dec 23, 2012 | 05:27 AM
HondaPartsHero's Avatar
Technical Hero
What engine do you have in it?
Old Dec 23, 2012 | 07:07 AM
gzes's Avatar
B16a3 but im gonna rip it out and sell and drop in a b18 hopefully
Old Dec 23, 2012 | 10:26 AM
Technical Hero
You'll want 92-95 civic DX/LX/EX. The VX and most CX have different 02 plugs. 92-95 Integra all models will work and be plug and play, the GSR will have some extra plugs for vtec, knock and IABs you can ignore.
Old Dec 23, 2012 | 01:09 PM
gzes's Avatar
Ok thanks bro
gzes
May 29, 2012 08:34 PM
a93and07si
Oct 15, 2008 02:00 PM
CaptinMcnut
Nov 12, 2004 05:01 PM
DragII
Nov 26, 2001 10:38 AM
