toe in/toe out, oversteer, understeer?
Old Oct 19, 2002 | 05:16 PM
sslude's Avatar
Default toe in/toe out, oversteer, understeer?
what is toe in/toe out, oversteer and understeer? could someone please explain this to me?
Old Oct 19, 2002 | 05:28 PM
Jesse H's Avatar
Default Re: toe in/toe out, oversteer, understeer? (sslude)
understeer: Front tires loses traction before rears. Headlights plow into guardrail.
understeer: Rear tires loses traction before fronts. Taillights plow into guardrail.
toe in: Wheels are pointed inward, like a bulldog's feet.
toe out: Wheels are pointed outward, like a duck's feet.
Toe out in the rear will help the car rotate more easily, but it will also be more twitchy at high speeds.
Old Oct 19, 2002 | 09:37 PM
ingrate's Avatar
25 Year Member
Default Re: toe in/toe out, oversteer, understeer? (Jesse H)
i also notice the steering is more responsive with minimal toe-out in the front
Old Oct 19, 2002 | 11:53 PM
carl_aka_carlos's Avatar
OVERsteer: Rear tires loses traction before fronts. Taillights plow into guardrail.
I think that's what he was trying to say!
Old Oct 20, 2002 | 01:30 AM
MikeSarr_GSR's Avatar
Default Re: toe in/toe out, oversteer, understeer? (carl_aka_carlos)
0 to -.1 is acceptable range for front toe
0 to +.5 in the rear is acceptable range for rear toe.
IMO/FYI
what this looks like with a microscope is this (more exaggerated)
\ \front / / toe out
/ /rear \ \ toe in
when your car is set up this way, your cornering will be more precise
as well as being more stable at highway speeds. at least this is the case
with my DC2. my settings are not completely tuned but here goes:
Potenza RE730s 205/50/15 on stock 1999 GSR rims
F: 1.75" lower than stock
Hot 32.5/32 psi 3/32s
comptech sport springs/koni yellows 335/330 60%/50%
stock GSR upper strut brace/stock lower stabilizer
Toe: -.08/-.1
Camber: -1.6/-1.5 (with me in it)
R: 1.5" lower than stock
Hot 31.5/31.5 psi 5/32s
comptech sport springs/GSR struts 135-195/130-190 rebound stat unknown
comptech 22mm rear swaybar/tiebar brace (set at the stiffest setting)
toe: +.45 +.5
inner tire wear is evident moreso in front... I still get 15K out of a set of Z rated tires if I dont rotate. I can see 20K if I let them go... the rears stay very much
in control all around. I can load my suspension very hard, I have about 165/128
at the wheels in my teg and I have no problem getting it to the ground. no wheel hop, no understeer... also taking the right lines DOES help...
[Modified by MikeSarr_GSR, 10:33 AM 10/20/2002]
PowerLeg
Jan 28, 2009 07:19 PM
zach1288
13
Apr 14, 2007 10:46 AM
blackdc5
Apr 15, 2006 07:32 PM
blackdc5
Apr 15, 2006 05:11 AM
jsi
Aug 18, 2004 05:25 PM
