another usual idle prob..
well sold my db8 and now i have an ek with a b16, my prob. is that i cleaned out the throttle body cause it was pretty dirty and now when i turn it on it stays to 2000rpm and doesnt drop..any tips on i can doo..thanx for the help guys..
take off your fitv and and unbolt the two 8mm bolts you'll see a white screw plug use two screw drivers and tighten it down don't force it tighten it until snug, it can become loose overtime not closing properly after your car is warmed up during initial start up, causing a vacuum leak, also check to see if your iacv is clogged if it is clean it.
accord-lude
Feb 1, 2006 05:57 PM
