P1259 VTEC System Malfunction Car will not start
Old Dec 17, 2012 | 04:27 PM
skaternak's Avatar
Default P1259 VTEC System Malfunction Car will not start
Hi, I have a 2000 civic ex d16y8. I havent started the car in about a week. I wanted to start it up to pull it into the garage. The car did not start. I have a scan tool and check the codes. The vtec system malfunction. All the hoses are in and grounds are good (grounding kit). Car started last time i tried to start it about a week ago. I wanted to take my other car to work that is why I havent used the civic. any help well appriciated.
Old Dec 17, 2012 | 05:08 PM
97_ek_coupe's Avatar
Default Re: P1259 VTEC System Malfunction Car will not start
Got to give us a bit more info bud, a vtec malfunction doesnt cause any starting issues. Does it crank? Are you getting spark? When was the last time you changed plugs and wires?
Old Dec 17, 2012 | 05:16 PM
grumblemarc's Avatar
The Grumpiest
I'll have to agree. never heard of a VTEC malfunction cause a car to not start. Is this a no crank or a crank and no start situation? Spark as mentioned above? If there is spark, what color is it? It should be bright white. Anything else and no start. Maybe something simple like a dead battery?
Old Dec 17, 2012 | 07:27 PM
skaternak's Avatar
Checked spark, it is good. I've charged the battery with a battery charger. Still no start. It cranks but would not turn over. Fuel pump primes and checked fuses. THey are good. But I did hear a slight buzzing from the fuel pump relay area. I've sprayed starter fluid into the TB and it starts but dies within 2 seconds. Im assuming its a fuel problem. But why would it show a vtec code?
Old Dec 17, 2012 | 07:30 PM
Former User's Avatar
Check whether all 4 fuel injector clips get battery voltage with the key in ON(II).
Old Dec 19, 2012 | 04:36 PM
skaternak's Avatar
how much voltage are they supposed to get?
Old Dec 19, 2012 | 04:38 PM
Fliptard's Avatar
When i first swapped my GSR into my EK, running OBD1, I drove it 15 minutes to work, ran fine.. went to start it later and It did NOT want to start nor stay running. I got a code (can't remember which one), but it was for the vtec. Took the Pressure switch off and cleaned the little whole it it. Car ran perfect afterwards
Old Dec 19, 2012 | 05:07 PM
Similar to voltage across the two battery posts.
Old Dec 19, 2012 | 05:16 PM
skaternak's Avatar
i tested the clip #1 the black wire gets battery voltage and red wire gets 2.2 volts. is it suppose to be like that?
Old Dec 19, 2012 | 05:22 PM
Your clips may be installed in the wrong firing order.
And the power wire is Yel/Blk, not Blk.
Old Dec 19, 2012 | 05:38 PM
skaternak's Avatar
the clips are in the same postion a week ago. I just never started it because i was driving my other car. So the clips did not get switched around. i'll try to send a pic.
Old Dec 19, 2012 | 05:42 PM
I was just pointing out that clip 1 should have a Brn ground wire, not a Red one (see diagram).
Cylinders are ordered 4-3-2-1 as you go from the distributor to the timing belt.
And the injector clip power wire should be Yel/Blk for all.
Old Dec 19, 2012 | 06:21 PM
skaternak's Avatar
i took a spark plug out when i was cranking and there was no gas in the cylinder. I thought I might have flooded the cylinder, but when i look in there was nothing in there. The fuel pump primes but the injectors are not getting grounded. And i just rechecked for spark and there is none now
Old Dec 19, 2012 | 06:22 PM
skaternak's Avatar
it might be the icm that went bad I checked it like the repair book says, but not getting the battery voltage to it
Old Jan 2, 2013 | 08:29 AM
skaternak's Avatar
it was the icm that was bad, i got a new distributor now. and i rented a noid light from the autozone. the light does blink when i crank the car. i think i might have flooded the cylinders because i took out all the spark plugs and they were wet with fuel. I just let the car sit overnight to let the fuel evaporate out. I'll let you know when i try to start it later today.
Old Jan 2, 2013 | 09:06 AM
skaternak's Avatar
okay now i got fuel and spark.. but still not starting. Its been sitting now for about 2-3 weeks. Is there a way to build up the compression in the cylinders without flooded the cylinders again?
Old Jan 2, 2013 | 11:24 AM
skaternak's Avatar
I checked the timing of the car. It is one tooth off. would that make it not start?
mr devious illusions
May 20, 2005 09:56 PM
b18c1eg2
Aug 21, 2004 12:28 AM
TeamCracka
Mar 13, 2004 11:57 AM
Kusai.Nihonjin.Desu
Aug 28, 2003 12:49 PM
DCtwoR
Jun 20, 2002 07:10 PM
