Del sol Headunit help
Earlier today i had a local reputable car audio installer hook up my after market radio in my del sol, After install everything was done clean and good but the radio will not turn on? and he had no idea why? So does anyone have any suggestions on why my headunit is not powering on?
Thanks.
Thanks.
Check fuse (ummmmm....) 15 or whatever...its the Radio, Cigarette Lighter , AUX fuse. Probably the culprit. It is located under the dash on the drive side.
If that does not help, you will need to pull the headunit out and start probing the connector to if for power. It is possible (but no likely) the installer hooked up the wrong power wires.
I bought the deck off someone but saw it work before i bought it. And the harness was hacked before i got it, But yeah i'll end up taking it some where to get it checked out but was just seeing if anyone had anything that might work lol.
meisnick
Nov 10, 2012 05:38 PM
bpotter05
Dec 9, 2011 08:22 PM
delsizzle1
Feb 21, 2011 06:04 PM
