97 Integra grinding noise while in gear
Old Dec 15, 2012 | 09:10 PM
mcfadden20's Avatar
Default 97 Integra grinding noise while in gear
First of all the car shifts 100% fine, without any problems, it does not pop out of gear nor grind going into ANY gears- it feels like its 100% normal...except for this noise.
Today while I was driving for the first time ever I noticed a noise, The noise does NOT happen when im in neutral and reving the car, clutch in or out...no difference ..no noise at all. There is no noise engaging the clutch IN or OUT at ALL. The noise ONLY happens when im actually IN the gear and driving under load, and it happens from like the first gear to the third gear, a constant grinding/metal to metal noise coming from tranny that continues to match the revs of motor in acceleration, it then goes away.
What possibly could have gone wrong from night to day?
Old Dec 16, 2012 | 02:57 PM
98lude-t's Avatar
Default Re: 97 Integra grinding noise while in gear
Sounds like main shaft bearing and possibly a clutch issue. I did a trans 2 weeks ago that has the to bearing stuck to the pplate caused noise a lot. Also main shaft bearing was eating itself for lunch.
Old Dec 17, 2012 | 07:18 AM
fcm's Avatar
fcm
Old Fart
Hmmm, the only thing that only moves when in gear and car moving is the differential and the drive shafts.
I would put the front end up on jackstands and see if you can localize the noise to see/hear if it is in the transmission or outside the transmission, [drive shafts, wheel bearings] maybe. 94
mychdb2gsr
Transmission & Drivetrain
Jun 7, 2011 04:15 AM
itsLOUiSduh
Mar 9, 2009 08:35 PM
xod
Oct 25, 2007 07:09 AM
david
Nov 7, 2005 09:24 AM
