94 honda accord ex coupe
Old Dec 15, 2012 | 07:58 PM
hondacrew86's Avatar
Default 94 honda accord ex coupe
I am throwing code 41 which is oxygen sensor heater and i replaced my o2 sensor and reset the ecu but i am still throwing code 41,...what could be the problem i need help. Also i put a full tank of gas in my car for the first time and it started to smoke the color is white smoke,...what could be my problem? its not a blown headgasket and my oil is not watery and my radiator fluid is fine?
Old Dec 16, 2012 | 01:39 AM
Hondaguy83's Avatar
Default Re: 94 honda accord ex coupe
Check Heater o2 fuse.then if you can test your o2 graph and if it isn't performing right its I recommend you to check your wires. Could be loose , open connection. I seem many cars also throwing that code if you have a rich mixture so u might wanna scope that out. Best is to check o2 graph
Old Dec 17, 2012 | 10:37 AM
Ill do that thanks,..ill let u knw if any of ur suggestion fixes the problem
spooledhonda
Apr 29, 2006 08:50 PM
inzecure1
Mar 18, 2004 10:43 PM
JDlvl InTEGRA
Nov 25, 2003 10:06 PM
94civic2nv
Oct 6, 2003 04:00 PM
