p1072 system too rich bank 1 YES I DID SEARCH
Old Dec 15, 2012 | 05:51 PM
sigsr01's Avatar
Default p1072 system too rich bank 1 YES I DID SEARCH
I have a 2000 Civic si, all original B16a2 motor trans 160k
My 1999 runs better then this 2000 Si.
p1072
spark plug replaced
ignition coil replaced
rotor button replaced
oxygen sensor bank 1 replaced
tested the injectors ... they're fine
the car runs like a diesel truck... im devastated...
could this be the catalytic converter? or timing issue?
I said converter since the car smells like SSSht when its on and timing since the previous
owner took it to a shop, maybe they did not do it properly.
Old Dec 15, 2012 | 06:51 PM
97_ek_coupe's Avatar
Default Re: p1072 system too rich bank 1 YES I DID SEARCH
I say either cat or exhaust leak. Check the manifold gaskets or for cracks
Old Dec 15, 2012 | 08:16 PM
sigsr01's Avatar
exhaust from header to tail pipe has no leak... i felt the car way slower than the 99 SI...
Old Dec 15, 2012 | 09:37 PM
jbpnoman's Avatar
How did you test the injectors? Have you done a fuel system pressure test yet?
Old Dec 16, 2012 | 10:34 AM
Syndacate's Avatar
^ This.
Check the fuel pressure via the access port on the filter, that'll pretty much give you what the rail pressure is. Make sure you use sealant tape or something.
I doubt it's the cat and I doubt even more-so that it's the timing.
I'd say the next step is to
A) Make sure you have adequate pressure at the rail
B) Make sure the injectors are operational
(I'm thinking B is your issue, since you said it's weak and it sounds like ****).
Old Dec 16, 2012 | 01:25 PM
sigsr01's Avatar
Originally Posted by Syndacate
^ This.
well.... im going to test the fuel pressure .... eventually buy a new set of injectors we'll see how that goes. thanks for the input .
Old Dec 16, 2012 | 08:21 PM
Syndacate's Avatar
Best of luck, man. Let us know what happens!
Old Dec 16, 2012 | 10:24 PM
beecee18's Avatar
"Runs like a deisel"
You sure your not missing a hole?
That would net you unspent fuel and possibly that code, And in time will surely ruin the cat if continually drivin like so.
Or a gnarkill exhaust leak before H02S1
If the engine is running rough check for compression at all 4 holes.
Old Dec 18, 2012 | 11:16 AM
sigsr01's Avatar
Went and grab a used set of injectors from a 50k em1 (looks and works good) still runs the same, i even went out and bought a new fuel filter.
ill see about the compression.... it just idles ugly..runs a bit decent with the new injectors...(i know this bc my brothers em1 runs better(which is for sale)lol..
Old Dec 18, 2012 | 11:28 AM
kyden's Avatar
i would first check fuel pressure.
Old Dec 18, 2012 | 10:13 PM
Syndacate's Avatar
Yeah, check the pressure.
Then do a leakdown and/or compression test to verify that the cylinders are sealing.
Then make sure you have power to each injector.
Also might want to verify that the spark plugs, cap, and wires are good. You can do a 'ghetto check' of the wires/cap by hooking a timing light up to them.
Old Mar 8, 2013 | 12:38 AM
sigsr01's Avatar
These things spark plugs, cap, and wires have been replaced and its new.
I forgot to update, so...
NEW UPDATE. I don't know what I did, but I reset the ecu and it went well.
Yee me!
Thanks anyways for the help guys!
skymanAR
10
Jun 7, 2013 12:14 AM
bluevic99
14
Aug 25, 2006 04:54 AM
TheBestCRX
Aug 29, 2004 01:20 PM
chill00
May 25, 2004 07:36 AM
