o2 sensor, 92 dx hatch
Old Dec 14, 2012 | 05:06 PM
Drama13's Avatar
Default o2 sensor, 92 dx hatch
My ecu is a p06, what o2 sensor do i need? the engine harness only has 1 wire for my o2 sensor but the o2 sensor in the manifold is a 4 wire. Do I need to get a 1 wire o2 sensor so it just plugs in or do i need to hard wire in the 4 wire o2 sensor for it to work properly?
Old Dec 14, 2012 | 05:28 PM
slowDB7's Avatar
Default Re: o2 sensor, 92 dx hatch
It sounds like you have a cx not a dx or someone swaped in a cx wire harness
Old Dec 17, 2012 | 06:38 AM
mrspeedy69's Avatar
Yeah sounds like you have a cx. I had this problem and just ended up buying a 4wire O2 harness and wiring it directly into the ECU. It worked great.
Old Dec 17, 2012 | 04:15 PM
moejoepotatoe's Avatar
I have a cx as well but with a p28 ECU and I am running a 4 wire o2 wired directly to the ECU.
Old Dec 19, 2012 | 12:23 PM
Drama13's Avatar
There is a wire that needs to go to a plug that has a wire for the injectors, iacv, and purge selenoid, the wiring diagram i was looking at says to add one of the wires from the o2 sensor to this plug, did you end up running a wire here as well, or where did you run the 2 wires that do not got back to ecu?
Old Dec 21, 2012 | 07:40 PM
Welderforlife's Avatar
i just did a swap on my 95 hatch that had a cx (d15b8) motor and harness to a dx motor with cx harness and am running a p06 ecu. i had to rewire in a 4 wire but only took about 20 mins. These are the links i used:
http://nzhondas.com/tech-help/123612...sion-obd1.html
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/
i spent hours researching so let me know if you need any help
Old Dec 23, 2012 | 06:10 PM
Drama13's Avatar
After hours and hours of digging and looking and researching this is what I came up with. Car is a 92 DX Hatch, the engine harness that was sold to me was for a CX (1 wire o2 sensor) problem should be solved by purchasing a proper engine harness for my car and then we will be golden. From what I have found and been told anyhow
Old Dec 28, 2012 | 05:47 PM
you can switch to a dx harness or wire it your self using the links i provided or i could take pics of how i did it
Markb16a
May 13, 2007 08:26 PM
chad
Aug 25, 2004 01:58 PM
alexb16hb
Apr 3, 2004 11:21 AM
civicmatt
Jun 22, 2003 07:27 PM
civicracer1993
Feb 11, 2003 06:35 PM
