p1457
Old Dec 14, 2012 | 04:11 PM
vegawrench's Avatar
Default p1457
my daughters 03 civic is starting to set p1457 have cleared twice w/ generic scanner checked fuel cap checked lines to evap canister? i'm a gm tech so i understand that evap codes can be tricky. don't know if i can smoke the system w/ the cheap scanner we have at work? is there any known causes that i might be able to check? thank you
Old Dec 14, 2012 | 04:33 PM
Crx_owner_20's Avatar
Default Re: p1457
P1457: EVAP Control System Leakage (EVAP Canister System)
People always believe its the fuel cap, its hardly ever anymore. Disconnect a evap line under the hood, command the vent solenoid shut with your scanner, smoke the system. Should show up, I've had a lot of these with the canister purge solenoid, but you need to smoke it.
FRKWOO
Nov 8, 2008 09:19 PM
Redbone
Aug 27, 2007 04:32 PM
sickofitall1113
Mar 10, 2007 06:13 AM
jdmaek
Jun 9, 2005 07:21 PM
boosted hybrid
Apr 2, 2003 09:53 PM
