PLEASE help me identify this distributor (part numbers)
Old Dec 14, 2012 | 01:02 PM
bart simpson's Avatar
Default PLEASE help me identify this distributor (part numbers)
PLEASEEE
Car is a 97 dx with a crx head(previous owner)
But the Cardone 84-17420 distributor I bought does not fit in the cylinder head hole(too big)
So I look up a 97 EX distributor, same part number,,, up next moved to a 2000 ex distributor but the plug is different. I am really stuck here =(
Please help me find out what I have =(
I Took a measurement of the part that goes inside of the cylinder head on a micrometer and got 1.258" (This is the one that fits my cylinder head)
Old Dec 14, 2012 | 03:58 PM
Tim512001's Avatar
Look on the head where the exhaust manifold bolts up it has four little circles one by each port. the farthest to the passenger side is the year its from, that may rule out crx if its 92+. And is that the only plug on it you pictured? It doesnt look like the one on my crx (90). You said its a 97 if i remember (i cant go look on phone app) if so thats gonna be an obd2 car isnt it? Which would rule out crx again unless your car has been changed over. Can u post a pic of the numbers or post the numbers on your old one?
Posted from Honda-tech.com App for Android
Old Dec 14, 2012 | 04:09 PM
Tim512001's Avatar
31-17420 looks like it(plug anyway). auto zone its for a 97 1.6 civic non- vtec
Old Dec 15, 2012 | 06:03 AM
94EG8's Avatar
Seagull Management
Default Re: PLEASE help me identify this distributor (part numbers)
That part that goes in the head is the same diameter on all '88 - '00 D-series heads, in terms of what fits what head there are only two different bolt patterns: OBD1 Vtec/vtec-e and everything else.
Old Dec 15, 2012 | 11:58 PM
Bolt pattern fits but the actual hole in the head is too small
Old Dec 16, 2012 | 03:24 AM
94EG8's Avatar
Seagull Management
It's possible you got one that was made wrong, but that was the correct distributor for the head.
Old Dec 16, 2012 | 03:31 AM
axis11's Avatar
Have you tried rotating the dizzy shaft 180 degrees. The part that mates with the camshaft is offset so that it can only be inserted in one way(the correct way).
Old Dec 16, 2012 | 08:48 PM
I have tried to rotate it, it literally is hung up on the cylinderhead. I can feel the aluminum to aluminum bind.
Old Dec 17, 2012 | 01:36 AM
HondaPartsHero's Avatar
Technical Hero
Is there any markings or labels that tell you TDxxx?
bart simpson
Aug 7, 2013 09:45 PM
E-Money
Nov 4, 2010 12:19 PM
aziaticvang
May 17, 2008 11:33 AM
RA61825
Mar 12, 2006 02:26 PM
HondaTomcat
Apr 14, 2005 11:45 AM
