whats the best crank for a gsr ??
thinking about all the possible modifications that i can do with the car .. and i kno changing crank is a good one ..
ive heard somebody say the b18c1 can take the ls crank but ive been told that :bs: wont work ..
anyhow im jus wonder which cranks do work and from yall experience which is the best one for the b18c1
you can install a ls 89mm crank into a b18c1 no problem,, not custom, you just need to use ls length rods as well
c1 an c5 block are the same thing, only the internals differ
i seen some b18b1 crankshaft n rods .. figured i would get those .. so there is no difference in the b18b and the b20 crank n rods ?? just want to make sure .. i know the b20 pistons would up my compression tho .. but im assuming i shouldnt take the b18b pistons ..
yes b20 crank and rods are the same as b18b.
you can't put b20 pistons in anyway. (unless you're sleeved, which at that point you wouldn't be asking this question).
What makes the b20 a 2.0 liter is the 84mm pistons vs the b18/b16 81mm
i must say coming from a nissan to a honda .. honda's are like lego blocks .. so many pieces can fit to all diff platforms ..
when i had my se-r if you wernt gonna go boost its expense and difficult to get various parts and choices to get a good n/a build ..
well in jamaica at least .. not sure what the n/a parts price and supply is like in the states ..
thanks again for the info .. gonna be getting a b20 crank next week as i sourced one out here .. get the pistons a little while later .. jus wish i had some itr pistons now
if your doin a N/A build and you want a little more compression
use p30 b16 pistons, with the 89mm crank and the c1 block youll be at like 11.2:1 compression ratio prob a little bit higher
p30's will be your best bet for compression, even more then itr pistons,,, stay away from ctr pistons, hi comp but there dome is to big,,, your cam choice's will be severely limited
plus the gas in jamaica is **** .. e-90 octane is the best we get at the pumps .. dont want to be running 12.5 or anything on that crap for a daily driver .. so the ctr pistons are fully a NO NO.. dome too big is right ..
not sure what FTFY means but im assuming it in agreement about the p73 and my shitty options in gas ..
off topic but as u say shitty gas .. was at the dyno where a subaru wagon was making 480whp on e-90 .. they dropped in the race fuel and that bitch made 620whp very next run
joedeezy
Oct 18, 2008 02:53 PM
