Need help diagnosing a missfire issue
Hey, honda tech I have a 91 crx with a b16a swap I'm using a obd1 Ecu,
I am having a problem with my motor sputtering, It runs fine when I first drive it, after 5min my motor starts to sputter and gets worse and worse.
Heres a little lead, I can hit vtec at 5800 when cold but once it's warmed up I try to hit vtec again and I get a code 21 which is the solenoid?
I didn't have this problem before when I first had the swap put in. I just need to check some issues, My oil level stayed the same I don't see much smoke coming from exhaust and my coolant level still the same as well where else can I check?
just changed spark plugs as well.
Bump, fixed the electrical issue it was my alternator, but my car still missfires, and tach sometimes stops working.
Also when I turn on the headlights at night it takes like 10 seconds for my dashboard lights to turn on.
When I hit Vtec, it sometimes throws a code 21 for Vtec pressure sensor.
Sounds like your distributor is failing, causing both misfires and tach issues. As for vtec, remove the solenoid assembly from the head and make sure the screens in the gasket are clean. But be prepared with a new gasket in hand before doing so. I wouldn't advise reusing the old one.
The dashboard lights problem sounds like a dead battery
BlakeJ53
Jun 2, 2008 11:57 AM
DraginTeg93
Mar 20, 2007 11:50 AM
