need help y8 into sedan problems
Old Dec 5, 2012 | 04:21 PM
slowestek's Avatar
Default need help y8 into sedan problems
so i recently swapped a y8 into my 90 civic sedan ex this is my first swap ever please bare with me on dumb questions. the motor is in the car it turns on but when i went to test drive it and it wouldnt go passed 1500 rpm and feels like its redlining any body have suggestions on what to do what it could be ?
Old Dec 5, 2012 | 04:39 PM
slowDB7's Avatar
Default Re: need help y8 into sedan problems
Ive had a problem like this before, i forgot to hook up my iacv and my car was stuck in limp mode it would only limit me to about 1500 rpm unless i got on the gas.
It sounds like one of your sensors may be unhooked and your ecu is running in limp mode too.. What ecu are you using?
Old Dec 5, 2012 | 05:02 PM
alex14's Avatar
how is the idle? it could be that your cam timing is off a tooth
Old Dec 5, 2012 | 05:07 PM
slowDB7's Avatar
That wouldnt cause it to seem like its redlining at 1500 would it?
Old Dec 5, 2012 | 05:15 PM
alex14's Avatar
possibly. if the valves are open when they shouldnt be then it wont make any power. post a good video of the cars problem. it will help us diagnose it.
Old Dec 5, 2012 | 09:17 PM
slowestek's Avatar
I am using the stock ecu that came with the car in think its a pm6 ill double check and the idle is good its right at 1000 doesn't play around its steady
I will check the iacv tomorrow thanks guys I will try to post a video so you guys can see it
Old Dec 5, 2012 | 09:42 PM
slowDB7's Avatar
Your ecu could be the problem, the y8 is vtec and the ecu pm6 ecu is for non vtec.
You might need a obd0 to obd1 ecu jumper and a p28 vtec ecu and possibly wire in your vtec solenoid
We will see when you post the video
Old Dec 6, 2012 | 07:40 PM
alex14's Avatar
if you havnt converted to obd1, thats probably some of the issue. did you wire for MPFI?
Old Dec 6, 2012 | 11:03 PM
McKinky's Avatar
If my memory is correct the ex sedan was mpfi out of factory. Now the y8 engine is sohc vtec so you will have to convert to obd1 and add in the vtec goodies .. or slap on a sohc non-vtec y7 head and you wouldnt need to convert to odd1. Depending on your skill and prices you can do either one.
Old Dec 6, 2012 | 11:52 PM
stichedskater's Avatar
swap your map sensor plug with the iacv plug you probably have them reversed
Old Dec 7, 2012 | 10:45 AM
alex14's Avatar
EX is MPFI, didnt see that part.
you need to post more details.
Old Dec 7, 2012 | 11:11 AM
4drEF's Avatar
Keyboard Humorist
^^^ this.
and are you getting a CEL?
What are the codes?
You can run the engine on your ECU... you just won't get vtec and it won't be running very well.
Better to go OBD1 with a P28, or a modified OBD1 ECU running a Y8 basemap or at the lieast a P28 program.
Old Dec 7, 2012 | 11:43 AM
DCRB's Avatar
swap your map sensor plug with the tps plug you probably have them reversed
fixed
Old Dec 7, 2012 | 06:46 PM
Originally Posted by DCRB
fixed
there you go couldn't remember what the f it was called... lol
roryss024
Dec 2, 2012 04:36 PM
uindaway
13
Nov 1, 2012 01:05 PM
mistahmac
Aug 14, 2007 12:24 PM
crazyhtch
Dec 17, 2005 06:55 AM
Wes90civic
Jul 15, 2004 07:05 PM
