crazy idle someone help
Old 08-12-2007, 10:19 PM
mistahmac's Avatar
Default crazy idle someone help
i recently did a y8 IM swap on my y7, and now my idle is off.
the swap went well and it idles fine at times. my problem is that when i drive around town my idle begins to bounce up to 2k and back down a couple of times and then goes to regular idle. i have checked my connections for possible leaks and everything seems fine. someone please help me. i don't want my motor to be retarded.
Old 08-12-2007, 10:57 PM
alacard's Avatar
What year car? sounds to me like a iacv problem. Are you aware of the iacv fix:
96-98(obd2a)
http://www.ff-squad.com/tech/w...8.jpg
99-00(obd2b):
http://www.ff-squad.com/tech/w...1.jpg
also what ecu are you running?
Old 08-13-2007, 07:50 AM
mistahmac's Avatar
my car is a 99 lx non vtec. i got a 96 auto vtec manifold so the 3 wire iacv is a direct swap. i kept my y7 tb and swaped the y8 rotor on it.
no cel.
i am running the stock computer. but i recently bought a p06 ecu for the turbo install coming in a few weeks.
Old 08-13-2007, 07:52 AM
luckii's Avatar
something u gotta clean above the manifold. forgot the name.
Old 08-13-2007, 08:37 AM
mistahmac's Avatar
you gotta be a little more specfic.
Old 08-14-2007, 12:19 PM
mistahmac's Avatar
bump....
Old 08-14-2007, 12:24 PM
dizzzane's Avatar
Default Re: (mistahmac)
Are you sure the TPS is good? Or that it doesn't need adjustment?
Zympress
Engine Management and Tuning
03-22-2016 10:19 AM
rollinhonda3
11-13-2010 09:53 AM
97ekcoupe
03-18-2007 09:32 AM
hondasport2000
27
08-24-2005 06:01 PM
dsadas89das78934
01-15-2004 08:01 AM
Quick Reply: crazy idle someone help
