How to add new ecu?
I'm running a stock p75 ecu on a b20b in my ej1. My new p75 came in the mail today and is waiting for me at my parents house till I get out of work. :/ It's chipped and base mapped for my setup on chrome. Do I simply plug this new one in or do I need to pull my ecu fuse or anything like that giving it time to reset?
I'm pretty sure I'll have to purchase a widband? I'm real new to this tuning thing. I don't have much money at the moment. Christmas bonus on the 11th though.
My car doesn't run to great with the stock p75. Smells like gas sometimes and has a strange idle here and there. Not the typical iac irratic idle. Back fires way to much also. If I'm on the highway cruising in 5th for a while and begin to slow down it backfires so hard it's insane. Has header and straight pipe to a 2010 oem si muffler. I've done a compression test and I'm 175 across the board. I'm not smoking or losing fluids. This new ecu should make it run better though until it's fully tuned passed the pre-existing basemap right?
I had the same exact prob with my 97 ej8 with a p2p and then I changed the tps it fixed all my probs was back firing real bad wld lag and take off and smelled like un burnt fuel and wld idle weird at times yea very irradic
My car doesn't run to great with the stock p75. Smells like gas sometimes and has a strange idle here and there. Not the typical iac irratic idle. Back fires way to much also. If I'm on the highway cruising in 5th for a while and begin to slow down it backfires so hard it's insane. Has header and straight pipe to a 2010 oem si muffler. I've done a compression test and I'm 175 across the board. I'm not smoking or losing fluids. This new ecu should make it run better though until it's fully tuned passed the pre-existing basemap right?Thread
pityocamptes
23
Feb 17, 2012 03:26 PM
