D16z6 mechanical timing question
Old Dec 5, 2012 | 12:31 AM
xGeNeTiCxFuNkx's Avatar
Default D16z6 mechanical timing question
I just redid my timing belt and was wondering if I did it right,
I set cam time marks at 9o and 3o I made sure of it cause I set it to tdc before taking belt off, now while doing this the crank moved slightly, so I stuck a screwdriver in no#1 cylinder and made sure it was tdc moving it up and down making sure it was exactly tdc, put new belt on cranked it back 3 teeth and tightend, maybe I'm stressing to much over it but I wanna be sure, it runs fine no miss or hiccup, idles fine and I no longer have belt whine, any input would be nice how did I do?
Old Dec 20, 2012 | 11:55 PM
swordofdoom's Avatar
Default Re: D16z6 mechanical timing question
Too much emphasis on the numbers, if you took some white out and made some dots on the teeths and the belt you wouldn't have so much of a hard time trying to find tdc.
Old Dec 21, 2012 | 01:55 AM
grumblemarc's Avatar
The Grumpiest
jawsiiv
Jul 21, 2009 01:07 PM
poundedhatchcrap
Oct 27, 2005 05:58 AM
zueke
Nov 28, 2003 08:38 PM
gsf4726
Nov 17, 2003 05:40 PM
TurboMiata
Dec 28, 2001 01:19 AM
