climate control
Old Nov 30, 2012 | 03:51 PM
boostitalready's Avatar
Icon3 climate control
im trying to do the 99-00 climate control bezel in my 97 civic. i have already ripped the old one out. i tried to fit the 99-00 and it didnt fit cuz the air vents. has anyone else ran into this problem??
Old Nov 30, 2012 | 04:32 PM
grumblemarc's Avatar
The Grumpiest
Default Re: climate control
You are supposed to do some modification! This isn't a plug and play install. Are you not following one of the MANY guides out there?
Old Nov 30, 2012 | 04:47 PM
deving916's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-%2A%2A-mother-all-how-tos-96-98-ek-manual-climate-swap-99-00-ek-electronic-%2A%2A-605432/
Old Nov 30, 2012 | 04:55 PM
datbumper's Avatar
You might wanna look **** up before you start just tearing it out lol. The biggest piece of advice I could give you, especially for a bigger, more difficult project like this, is to do as much research as possible. If you don't know what to do, definitely don't start tearing stuff out.
Old Nov 30, 2012 | 05:16 PM
its not that hard ive already ripped it out for my gauges, so this isnt that bad. im not trying 2 replace the whole dash. i just have a question on the fitment. i just want to know if i need new vents, b/c the 99-00 hits the 97 box vents when trying to put it in
Old Nov 30, 2012 | 05:18 PM
i kno its not plug and play, just the hazards and heat. i have no ac lines or compressor. already ripped that out. are you not listening to ANYTHING i say?
Old Nov 30, 2012 | 05:21 PM
The Grumpiest
You only mentioned air vents. Which are not plug and play.
Did you look at the DIY link provided? It's pretty self-explanatory how this swap goes.
Old Nov 30, 2012 | 05:32 PM
like i said im not ripping my whole dash off
Old Nov 30, 2012 | 05:34 PM
The Grumpiest
Good luck with that. The ducting has to be replaced not just the vents. Can't do that without removing the dash. No where does it say the dash gets REPLACED. Oh. You already posted in that thread asking how to cut corners because you don't want to do the whole job.
Maybe you might want to find another DIY that shows how to get around it. Good luck with that too.
Old Nov 30, 2012 | 07:28 PM
datbumper's Avatar
For some reason, I think you would look exactly like your avatar in real life, grumble.
egekcivic
Sep 18, 2012 06:09 PM
coupe_hybrid
May 25, 2005 07:01 PM
JDM_EK
Jul 8, 2003 04:12 PM
