91 Civic Hood Stuck Closed
When i first bought this car i needed two people just to open the hood. my gf would have to push down on the hood while i pull the latch then it would pop open. now it just stuck closed. would i have to replace the latch and the latch cable? and how would i get it to open so that i could fix it. can anyone tell me??? this car is becoming a nightmare!
i had this same issue. your hood release cable is stretched. For a temp fix, unhook the cable from the latch inside your car and use a pair of pliers to pull the cable straight out towards your shin to release the hood. You will need to change the cable which requires removal of the drivers fender and bumper. Its not hard, just time consuming.
Meh,I installed a bicycle cable adjuster on both of muh EFz stretched cables... (have to enlarge the hole in lil metal bracket a bit though) Both give me zero issues now,ha!
Seriously? mmkay, here ya go (shitty cell pic,but should suffice I suppose?):
Also had to "whittle" a bit of the plastic on cable end so would fit in teh lil cable adjuster btw.
(It will be evident what is required once you're @ it) Just be SURE that hood latches COMPLETELY secure after! (meaning not releasing it when handle isn't being pulled!!!)
Thx,nothing but a thing mang! (got tired of holding handle + reaching out to beat on muh 88 sedan's hood! def embarassing! simple $1.00/5 min solution to a PITA common problem,check out some of my better EF mods in my build threads sometime when bored...
The lil bike shop near me gave me 1st adjuster for free,2nd one for my obnoxiously loud-prolly-bothering-them-on-a-daily-basis 91 rex they charged me $ for,lol...
DsMWookie
Sep 14, 2005 09:04 AM
sidewayz
Mar 12, 2003 07:28 PM
