Fuel pump wiring.
Old Nov 28, 2012 | 06:25 PM
GT500FTW's Avatar
Default Fuel pump wiring.
I'm running twin external pumps. (Walbro 225 feeding bosch 044)
The stock fuel pump wiring doesn't look too impressive.
I'm going to be hard wiring the pumps with a direct feed from the battery, but don't want to use a relay. I'm just going to have a large switch.
Do I need a relay if I'm going to hard wire them?
Any info/advice would be appreciated.
Thanks.
Old Nov 28, 2012 | 06:47 PM
GT500FTW's Avatar
Default Re: Fuel pump wiring.
Ok, so the admins decided to move this thread from the "electrical queries" section to the tech/misc section.
I'm confused.
Old Nov 28, 2012 | 06:52 PM
MR.johnson's Avatar
dont just run them off a switch. it's 2012.
http://www.r1200gs.info/howto/images/Schematic4.gif
Old Nov 29, 2012 | 08:27 AM
GT500FTW's Avatar
What are the negatives of just running a switch?
Old Nov 29, 2012 | 11:55 AM
surfingsk8r's Avatar
The negatives would be that if it shorts out you get a fire
Old Nov 29, 2012 | 01:19 PM
GT500FTW's Avatar
The way I see it, the relay just allows a high voltage circuit to be turned on by a low voltage circuit. I'm not using oe wiring, and I don't mind switching the pumps on every time I get in the car. Is there not just as much chance of it shorting out using a relay as using a switch?
Old Nov 29, 2012 | 07:03 PM
swordofdoom's Avatar
I like to see your car spray fuel all over the place and burst into a mad raging flame as you forget to shut off the switch and leave it running while your parked and sleeping. Every car has a relay and its for that exact purpose, because people are idiots who forget.
Old Nov 30, 2012 | 11:29 AM
GT500FTW's Avatar
A bit harsh!
Good point!
Thanks for the input
Old Nov 30, 2012 | 11:46 AM
mechanix619's Avatar
You'll only be using the OEM wire to trigger the relay.
Quickridez_3
Mar 24, 2015 05:43 PM
1GPlusSH
Honda Motorcycles
Oct 26, 2012 01:56 PM
ryanxmx31
Jun 4, 2007 09:28 PM
erikiksaz1
Audio / Security / Video
15
Mar 29, 2005 03:41 PM
dom93hatch
Jul 15, 2003 08:48 PM
