Condenser fan not working
Old May 5, 2011 | 09:06 AM
jackiewogn518's Avatar
Default Condenser fan not working
my F20B motor have changed to use OBD1 P28 ECU recently, it using the OBD2B to OBD1 conversion hardness with P28 ECU. However, I found the ac condenser fan is not turn on when I switch on the ac.
Suspect is the ECU or the conversion hardness problem...
Any one can advise on that?
Old May 5, 2011 | 06:33 PM
Default Re: Condenser fan not working
bump!!
provide more information......the ac clutch is engaged when i switch on the ac....but the condenser fan is not working...
Any one can help!?
Old May 6, 2011 | 06:15 AM
bump!!
I have tried to fallback to use orignal ECU(OBD2), the ac condenser fan is working fine without any issue....once switch on the ac, the ac condenser fan will turn on together...
Any one any help?
Old Nov 27, 2012 | 05:39 PM
Kris_purser's Avatar
I am having this problem. Old thread but looking for any answers. Can anyone help?
Old Nov 28, 2012 | 05:58 AM
fcm's Avatar
fcm
Old Fart
MM&Y of car would help, along with any mods.
Have you checked anything yet, is the condensor fan any good, will it run if powered directly, have you checked fuses, condensor fan relay, anything? 94
Old Nov 29, 2012 | 09:57 PM
I have a 2000 accord ex coupe. New F20b swap that's giving me a huge headache. Chipped p28. All physical components are in good working order.
I've recently discovered that the temp gauge doesn't respond to the type of signal the p28 sends to it. Does the breakdown in the ECT system using the p28 affect the condenser fan as well? How can this be fixed?
Old Nov 29, 2012 | 10:34 PM
holmesnmanny's Avatar
If you're looking at it using your laptop the temperature you are seeing from the ecu is coming from the engine coolant temperature sensor. The temp gauge on the cluster is getting its reading from the temperature sender that is located next to the coolant temperature sensor below the distributor. The one prong is the sender and the two prong is the sensor.
Old Nov 30, 2012 | 02:47 AM
This is not correct for my motor. There is no sending unit. It has been integrated into the coolant temp sensor. My accord only has 2 plugs: coolant temp & fan control.
Any other advise?
Old Nov 30, 2012 | 02:03 PM
I was responding to the OP without realizing the date.
geribair
Jun 7, 2014 11:18 AM
Blackbird435
Honda Civic (2001 - 2005)
Jun 12, 2013 08:50 AM
civicman69x
Jul 24, 2008 08:10 PM
kurokojin
Aug 17, 2006 10:37 PM
