transaxle help please
Old Nov 28, 2012 | 02:44 PM
Hatchbacksonly's Avatar
Default transaxle help please
for the last few days my tranny has been grinding going to 4th and its been slipping so i though my clutch was going out but today i was driving down the street and my tranny got stuck in first gear so i yanked it out and no my tranny wont go into any gears would it be the clutch or has the tranny seized up
Old Nov 28, 2012 | 02:47 PM
4drEF's Avatar
Keyboard Humorist
Default Re: transaxle help please
Sounds like a worn transmission.
However I have had odd issues when engine mounts go bad.
Old Nov 28, 2012 | 02:51 PM
RanCRX's Avatar
I would check your shift linkage u-joint part. They're known to get all loose eventually and screw some shiznit up. If it is the shift linkage, you gotta get a new one. Also look at your shift linkage bushings and make sure your transmission oil is full and up to par before deciding.
Old Nov 28, 2012 | 02:52 PM
if i play with the shifter a little bit i can get it in gear but i dont know which one lucky i was down the street of my brothers house btw im running a d16y5
Old Nov 28, 2012 | 02:57 PM
RanCRX's Avatar
It's most likely your shift linkage. When you put it in gear can you move the shifter left and right? It's only suppose to have half an inch of play. Don't forget to check the bushings
Old Nov 28, 2012 | 03:05 PM
i can only get it in first and reverse but it only has about 1/2 an inch play on each side
Old Nov 28, 2012 | 04:46 PM
hatchmasterjay's Avatar
will it go into gear with the engine off?
you could drain the fluid and have a look at it.
Old Nov 28, 2012 | 04:50 PM
it sounds like it does but not 3rd or 4th so i think it might be the sychro im gonna try to pull it tomorrow
Old Dec 2, 2012 | 04:20 PM
i figured out it was my shift linkage that broke how much would that cost me?
dsd1_209
Transmission & Drivetrain
Nov 1, 2012 06:53 PM
bowdown201
Jan 8, 2009 10:19 AM
203_DC5
Apr 1, 2007 11:10 PM
honcrx91si
Aug 25, 2006 08:24 PM
Apollo
Oct 5, 2003 04:39 PM
