i need some help!!!!! got motor mount problems
Old Nov 27, 2012 | 08:51 PM
guffey10's Avatar
Icon2 i need some help!!!!! got motor mount problems
I bought a 96 ek hatch and the passenger side motor mount holes are stripped and I believe at least one of the tranny bolt holes is stripped I'm putting a rebuilt ls block with a b16 head in it I have all the right mounts and brackets to do the swap but need to know the easiest way to fix this problem with the mount holes
Old Nov 28, 2012 | 03:46 AM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: i need some help!!!!! got motor mount problems
You can drill out the holes and tap for the hole for the next size higher up.
Or you can use one of these.
http://www.timesert.com/
way better than a helicoil and more sturdy.
Old Nov 28, 2012 | 09:32 AM
guffey10's Avatar
Post Re: i need some help!!!!! got motor mount problems
Thanks also I believe their is a bolt behind the hole I think one of them broke off when we was trying to get the bolt in does that change anything
grog
Apr 25, 2008 06:44 AM
allmotorh22
Nov 24, 2006 08:30 PM
Herminator
Welding / Fabrication
Oct 22, 2005 04:00 PM
00WhiteEKy
Jun 22, 2003 08:54 AM
00WhiteEKy
May 30, 2003 10:09 AM
