97 civic ex rocker arms torque specs
Old Nov 26, 2012 | 09:20 PM
macho5690's Avatar
Default 97 civic ex rocker arms torque specs
I have a 97 civic ex and i got my head resurfaced. After putting everything back together there is a small knocking noise coming from the valve cover. It has a few nicks underneath it showing that something is hitting it. So I was wondering if anyone knew the torque specs for the rocker arm bolts, so i can make sure they are down all of the way. If any other advice on the small knocking noise on the valve cover it would be greatly appreciated. Thanks in advanced!
Old Nov 26, 2012 | 09:22 PM
jbpnoman's Avatar
Default Re: 97 civic ex rocker arms torque specs
Did you set your valve lash correctly? Information can be found in the stickies.
Old Nov 26, 2012 | 09:57 PM
macho5690's Avatar
Sorry im kinda new too all this. But if you mean the valve clearance I went by the numbers in the service manual after i heard the banging against the valve cover. After i did the valve clearance, I put the cover back on turned her on and everything sounded great, but after i put my foot on the gas and revved it up a little, the banging started again. I dont mean to sound desperate, but shes been sitting in my lot for quite some time and i want her running perfectly again. Once again thanks in advanced!
Old Nov 26, 2012 | 10:10 PM
jbpnoman's Avatar
Is this what you did?
Old Nov 26, 2012 | 10:35 PM
macho5690's Avatar
Yes that is what I did
julianbc2
Dec 30, 2008 04:14 PM
my93hatch
Feb 16, 2005 04:19 PM
hott-nix
Apr 15, 2004 01:01 PM
ATS*Mark
Aug 30, 2003 10:03 AM
1fastGSR
Oct 1, 2001 04:20 PM
