idle rpms
I would go ahead and clean the iacv and fitv, if that doesn't fix your problem, then i would search for a vacuum leak.
Are you sure it doesn't bounce when it warms up? not even a little bit?
Also does it stay at 1000 rpm even when its warmed up and at optimum temperature? 1000 rpm is pretty high for a up to temperature motor, no? I know my motor after being warmed up goes from idling normally at 600-700 rpm to randomly jumping and staying at 1000 rpm which in result disables my vtec...
Shauntron
Apr 25, 2007 12:06 AM
