Obd1 intake manifold on obd0 block
yeah it will work . im doing mpfi swap . i got almost everythin i need except the dizzy but i should have that by friday . oh n a fuel preasure regulator but thas no biggie. so far ive been lucky havent spent any thing . just google mpfi swap theres a ton of info out there.
Ok so finally start searching the right things and what I now know for sure, is that it's already been converted to mpfi (4 injectors instead of two injectors).
From what I can tell, the only big "uh oh" is that I'm gonna have to get Y flanges for some of the vacuum lines so they will all fit. And I'm about to attempt to take off the fuel line going to the odb0 fuel rail so I can attach it to the obd1 rail. I'm also gonna have to get another iat sensor cuz mine is completely stuck to the obd0 intake manifold and is also busted..
Ok so the obd1 P06 intake manifold it damn near plug and play.
The only thing you have to do is,
Extend vacuum lines and reroute some them to other spots.
I used the obd1 throttle body and iacv and it's great!!!
The intake manifold size is almost double in size! Too bad I don't have a computer, otherwise I'd post pictures.
thedudefromjerz
Feb 21, 2008 02:52 PM
mengy007
Feb 2, 2006 09:21 PM
Gant
34
Jul 24, 2004 01:59 PM
