Sound-deadening Heat Barrier what do you use?
Old Nov 25, 2012 | 04:53 PM
ZCHondaCRX91's Avatar
Default Sound-deadening Heat Barrier what do you use?
On my CRX I noticed if I sit at a stop light for a couple minutes and then start driving I feel heat from the engine on my legs. I feel it in the winter, but in the summer it's annoying because it's hot out to begin with. I figured the heat is going through the firewall and using some barrier I can keep it out. I really just need a heat barrier, but sound dampening wouldn't hurt. I saw dynamat sells some sheets, but I also saw brands like Summit and Eastwood selling cheaper sheets but seem to be the same thickness and quality. What do you guys use? What is the best heat barrier?
I figured I would put some small sheets around the hatch area and on the doors to reduce rattle, but is there a big advantage to doing the whole floor with it? Any experience/advice is appreciated.
Old Nov 26, 2012 | 04:32 PM
TunerN00b's Avatar
Default Re: Sound-deadening Heat Barrier what do you use?
If you really want to stop the heat, then you want reflective foil. However, that won't do anything for sound or rattling.
Old Nov 27, 2012 | 09:03 AM
Does that only work on the engine side of the firewall or does it work on the interior side?
wantboost
Welding / Fabrication
40
Aug 15, 2012 11:32 PM
R.Storvick
17
Jun 7, 2009 10:44 AM
danielm3
Oct 16, 2006 11:58 AM
all stock
21
Apr 28, 2003 03:55 PM
stealthteg
Apr 18, 2002 11:30 AM
