full blown dual pump fuel gauge problem help!!!!
i purchased a full blown dual pump kit and i installed it into my ek hatch wired it up to a relay and fuse everything thing works fine but my fuel gauge doesn't work anymore.... anyone know why this would happen or has this happened to any one?!?!?!
i used the search to find out if anyone had this problem but couldn't find anything, please help need this fixed
The oem hanger does not have a float valve attached to it. Are you guys sure you did not unplug the wrong harness?
You shouldn't have to touch the float valve when you install our pump hanger
im only doing the hanger side but when wirring up the pump do u use 1 relay or 2? i have mine on 2 and i think that might be it idk when i get home ill check the floater to make sure it good
CTR_B
May 24, 2009 02:20 PM
Wherm5150
Feb 3, 2009 07:26 PM
