Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Input shaft bearing, what bearings to replace?
Old Nov 25, 2012 | 12:32 AM
TravisBiggie's Avatar
Default Input shaft bearing, what bearings to replace?
2005 civic LX
I have the notorious input shaft bearing noise. Loud as **** without the clutch engaged, goes away with clutch engaged.
I am going to pull the tranny soon myself, and I know someone who can open it up and replace the bearings.
I'm sure this guy knows what bearings I need, but I want a second opinion. I was told 3-4 bearings should be replaced while the transmission is opened up. Any info of these bearings will be greatly appreciated. I need to get these things replaced asap so I can sell the car, because the bearing has gotten much louder recently.
Thanks
Old Nov 25, 2012 | 02:00 PM
It Wasn't Me's Avatar
Default Re: Input shaft bearing, what bearings to replace?
https://honda-tech.com/forums/honda-civic-2001-2005-78/input-shaft-bearing-replace-rebuild-3065844/
That should provide at least some input.
Some people like to skimp and only replace the MIS bearing, others replace all case bearings. Doesn't hurt to do it all at once to avoid having to take it all apart when another bearing goes bad. Whichever bearings are not functioning smoothly or have any play in them, replace them in addition to the MIS bearing.
Personally, I'd replace all of the case bearings though some may think this is unnecessary.
StockDC2
Jul 8, 2017 01:59 AM
canadaek
Transmission & Drivetrain
Nov 6, 2012 02:05 PM
civic ef
May 29, 2012 01:02 AM
SlowPokeEg
Sep 23, 2006 01:49 PM
The Toecutter
Apr 24, 2002 07:24 PM
