Welding Shifting Fork S40 Trans
Old Nov 24, 2012 | 04:31 PM
drsab2000's Avatar
Default Welding Shifting Fork S40 Trans
I have opened my 1999 Honda Civic 5 speed to replace the input shaft bearing and upon inspection found the 3/4 shifter fork to be worn pretty badly. I did not have any shifting problems just a noisy bearing. I've heard somewhere that it is possible to built up the worn area by welding then grind down the fork. I have access to a machine shop at work. Has anyone done this with success? Can you pass on some advice? Thanks in advance.
T
Old Nov 24, 2012 | 04:55 PM
drsab2000's Avatar
Default Re: Welding Shifting Fork S40 Trans
Attached are some pics.
Old Nov 24, 2012 | 06:23 PM
jbpnoman's Avatar
Check clearances and compare them to spec before you go fiddling with welding it. I've seen people weld/sand before, but it's generally a last resort kind of thing.
Old Nov 24, 2012 | 06:30 PM
94EG8's Avatar
Seagull Management
I welded a bunch of them and they always worked fine. Weld at the ends and the middle
Old Nov 25, 2012 | 05:14 AM
drsab2000's Avatar
94EG8
What type of welder do you use (mig, tig)? How do you finish the part (hand file, mill, grinder)? Thanks.
T
Old Nov 25, 2012 | 05:47 AM
94EG8's Avatar
Seagull Management
Originally Posted by drsab2000
94EG8
T
Just a 180 amp mig with gas. I just build it up and then grind it down with a bench grinder. Then clean it up with a file if necessary.
Old Nov 25, 2012 | 06:38 AM
Former User's Avatar
Sounds like you'll take the welding option, but you can also buy a new shift fork for $64 at Majestic Honda.
Old Nov 25, 2012 | 07:06 AM
cheggie's Avatar
Not a bad option, considering the labor and aggro to open it up again if the grinding method doesn't work. I think I'd scrap the bad shift fork and replace it.
Old Nov 25, 2012 | 08:10 AM
94EG8's Avatar
Seagull Management
Even at $64 it's not worth it. D-series transmissions are just this side of worthless. If you have free access to a welder and about 20 minutes of free time you're better off just welding it. Also those forks aren't hardened so they don't get any softer when you weld them.
Old Nov 25, 2012 | 02:08 PM
drsab2000's Avatar
The forks are not hardened and actually relatively soft. It seems the 3/4 fork has a smaller contact area then the other forks (the others show no sign of wear and are well within in spec). The sleeve is hardened and chews into the fork. I agree that it seems risky to try the welding path because if it dosen't work there is a lot of time involved to do the job over again. I'm going to try welding the fork. If I don't like the results I will buy a new one. Thanks for all the help.
P.S. Regarding the input shaft bearing, it's way to small for it's location in the trans and is probably why it's a comman failure point.
weekendboost
Transmission & Drivetrain
11
Sep 25, 2018 09:16 PM
Eight09
13
Jun 21, 2015 06:26 PM
bks84
Dec 1, 2012 09:11 PM
sleeperrex
Honda Civic (2001 - 2005)
Sep 14, 2010 06:41 AM
wiZCo
12
May 14, 2007 09:16 PM
