Flat tyre noise / loose blet noise
Old Nov 21, 2012 | 03:48 PM
Bushera's Avatar
Icon2 Flat tyre noise / loose blet noise
Hi All, I need herp trying to work out a noise that as soon as I speed up, slow down and turn right occurs. I have just had the car serviced but this noise was happening before the service, the machanics checked everything out and couldnt find any issues. The sound seems to be comming from the driver side, the CV boot and steering Boot has been replaced recently and the bearing were looked at, all tyres are brand new and have been alligned and balanced.
The noise sounds like a flat tyre noise / loose belt, it's driving me up the wall as it was only when I truned right and now it's also when I speed up but the sound gets quite lound when I hit around 60 and also when i am slowing down.
The breaks were also checked and are only 30% used.
Any ideas anyone, the car is a 1996 Honda accord VTi-S with lowered suspension again fairly new.
Cheers
Old Nov 21, 2012 | 07:06 PM
jdowen2's Avatar
Default Re: Flat tyre noise / loose blet noise
If the cv boot was replaced you probably lost a lot of grease before hand and the cv joint is bad. Get the car off the ground and pull both front wheels and check cv joints and wheel bearings.
Old Nov 21, 2012 | 10:01 PM
Bushera's Avatar
Hi, I just had a look and it doesnt seem to be the CV or bearings, any other ideas.... thanks for your advice
RG5384
Apr 29, 2013 12:59 AM
RacerTim
Apr 6, 2010 08:12 AM
BlackZ
May 31, 2008 11:19 AM
LX4CYL
Jan 31, 2004 11:32 PM
Gen5_EG
Nov 10, 2001 09:05 AM
