best piston/piston kit to rebuild a b16a with?
hi guys, wondering what type of pistons or piston kit to buy for this engine? im gonna need everything, gaskets and all of course, i was thinking wiseco but they are 500 bucsk for pistons only and dont even include all the gaskets?
im also thinking higher comp than the stock 10.5:1, i think its 10.5:1? wouldnt mind something a bit higher that will still handle 91 octane fuel,, thanks!
start off in tearing down your motor and then seeing if its worthy of a rebuild.
that way you arent wasting money/time on having to send them back if your motor is not in the best shape.
and best, well i mean a good piston, something thats reliable and going to work or wont fail, i see on ebay there is tons of piston kits but i think, i guarantee most of them are cheap and crappy pistons....
so im asking here what do guys run? brands? kits?
like i said, i figure while im at it i was thinking to raise the comp ratio for the hell of it
"For the hell of it". Not very technical.
What purpose do you need aftermarket pistons for? Might as well get OEM and be done with it.
so, if oem is good, then thats good, but i figured higher compression just to give it a lil more "kick" or power
Just curious. OEM oil rings go bad? Who told you that? More kick? How did you figure that? And what precisely does "kick" mean?
and kick, well give the engine some more torque or what ever, i know higher compression usually = not as high reving but helps give some more torque through the range
As far as the burning of oil, Honda valve seals tend to be one of the main culprits of oil smoke in Hondas. You should prolly rebuild your head inspect and lap the valves and replace those seals, if you want you could even do a quick port job....
do you have anything you'd recommend doing to this b16 while i have it appart? my thoughts where a bit higher comp pistons
b18sihatch
Jul 10, 2006 08:35 AM
ActiveAero
Jan 2, 2004 11:51 AM
Underground
10
Jan 29, 2003 10:48 AM
mikeSONICGSR
Oct 1, 2002 08:13 AM
