?can i still go FI if i have piston slap?
Old Oct 18, 2002 | 04:11 PM
shermanyang's Avatar
Default ?can i still go FI if i have piston slap?
as the topic states. is it safe to introduce my motor to FI if i have forged pistons that's causing piston slap? i really want to be able to run at least 7psi and max out at 10psi. would i be safe running 7 psi?
Old Oct 18, 2002 | 04:12 PM
D-SPEED's Avatar
Default Re: ?can i still go FI if i have piston slap? (shermanyang)
piston slap can just be part of having aftermarket pistons, FI does not relate with it.
Old Oct 18, 2002 | 04:16 PM
Aeka GSR's Avatar
New User
Default Re: ?can i still go FI if i have piston slap? (D-SPEED)
but on stock pistons it is a sign of loose pistons. I've got a little bit of slap on stock internals and im boosting 8lbs
Old Oct 18, 2002 | 04:20 PM
dustin's Avatar
As the experts tell me.. you sacrifice ring life but there aren't any other serious effects other than noise...
Default Re: ?can i still go FI if i have piston slap? (Aeka GSR)
cool, so i'm guessing it's safe to go ahead and boost. oh well, if anything goes wrong the worse that could happen would probably be blown rings. hopefully these Total Seal rings can stand up to their name.
Old Oct 18, 2002 | 04:27 PM
ion_four's Avatar
Old Oct 18, 2002 | 04:29 PM
dustin's Avatar
Default Re: ?can i still go FI if i have piston slap? (ion_four)
uh oh
BoostedD15B7
Oct 14, 2003 04:18 PM
boostedinteg03
Apr 15, 2003 12:06 PM
ek
Jun 10, 2002 08:52 AM
boosted3g
Nov 7, 2001 01:49 PM
