whats a good set cams for a stock gsr?
Old Nov 21, 2012 | 04:20 AM
munrchah's Avatar
Default whats a good set cams for a stock gsr?
hey guys looking for some advice on cams for a stock compression gsr ,i was looking at the edelbrock 4730 mainly for the low price but all reveiws have been on turbo builds. i already have supertech dual spring but was wondering if i need to do titanium retainers or can i use stock? also do i need to uprade injectors to tune with more agressive cams?
Old Nov 21, 2012 | 05:17 AM
jazzRS's Avatar
Default Re: whats a good set cams for a stock gsr?
go skunk2 tuner 2. obviously any set of cams is going to benefit from supporting mods. not sure what else you have done but those cams seem to be a popular choice for mild builds
Old Nov 21, 2012 | 06:50 AM
DDTECH's Avatar
Search username "SoloDC".. You'll find your answer there.
Upon the search you can also see sig
Old Nov 21, 2012 | 05:56 PM
soloDC's Avatar
OP: I'm on a stock Comp GSR bottom end. I went with the DD-Tech Stage 1 Cam grinds!
Old Nov 21, 2012 | 07:25 PM
munrchah's Avatar
thanks for the sugestions guys but i looking for more affordable cams i am sure those dd tech cams are badass but i am trying to stay in the sub 600 dallar range . also do i need to upgrade retainers?
Old Nov 22, 2012 | 01:36 AM
angryhillbilly's Avatar
Wise choice to get titanium retainers. For cheap and decent power check out blox type b. Or skunk2 tuner 2
Old Nov 22, 2012 | 03:55 PM
munrchah's Avatar
what is the purpose of the titanium retianer besides wheight?
Old Nov 22, 2012 | 04:02 PM
v4lu3s's Avatar
RTFM
if you are running mild cams and not revving much past stock red line they are just a waste of money.
Old Nov 22, 2012 | 04:27 PM
DDTECH's Avatar
My cams are perfectly affordable, PM me for pricing.
As far as VT upgrade, its always recommended , even with stock cams. Its one of the single most important things to upgrade!..
Old Nov 23, 2012 | 11:28 AM
kulo's Avatar
Ek9 cams are good oem setup
Old Nov 24, 2012 | 01:54 PM
munrchah's Avatar
does anybody know anything about the edelbrock 4730 cams
SiR-iNTEGRa
Mar 2, 2012 01:20 PM
Egpower88
Feb 14, 2009 07:32 PM
---SPEED-DEMON---
Jan 14, 2008 12:58 PM
crazyimport
Jun 30, 2007 12:43 PM
98B18C1
Oct 10, 2005 08:27 AM
