Choosing FI cams...
Old Jun 30, 2007 | 12:12 AM
crazyimport's Avatar
Default Choosing FI cams...
I'm currently running GSR cams with ITR valvetrain on a stock b16 head with stock vavles.
Im looking to upgrade cams before i hit the dyno up.
Can i run Skunk Pro1 cams on mysetup or should i just settle with Type R's??
Thanks!
Old Jun 30, 2007 | 12:15 AM
GetawayInMoscow's Avatar
Default Re: Choosing FI cams... (crazyimport)
You will need to upgrade your valvetrain for Pro 1's. ITR valvetrain is pretty pansy.
Old Jun 30, 2007 | 12:16 AM
Default Re: Choosing FI cams... (GetawayInMoscow)
ah damn it... THought it might be ok
Old Jun 30, 2007 | 12:47 AM
SD_Lurker's Avatar
HT White Ops
What kind of numbers are you looking for? GSR cams a great for a boosted application. I don't think its necessary to upgrade your cams especially if your not looking for high numbers. Also, like stated above, you would need to upgrade your vavletrain. Skunk2 pro 1's have been tested against GSR and they yielded quit a bit more power.
Old Jun 30, 2007 | 12:52 AM
quik sol's Avatar
stick with the GSR's unless you want to change your valve train, then by all means...go skunk2 pro's
Old Jun 30, 2007 | 03:39 AM
DaveF's Avatar
Default Re: (quik sol)
did anyone bother to ask what turbo/turbine housing the OP is using ?
Old Jun 30, 2007 | 07:03 AM
Default Re: (dturbocivic)
gt35r .70 a/r
Old Jun 30, 2007 | 09:25 AM
Default Re: (crazyimport)
With ITR valvetrain you might as well run ITR cams. A lot better than GSR cams but more expensive as well.
Old Jun 30, 2007 | 12:23 PM
eastbay92cx's Avatar
Default Re: (GetawayInMoscow)
I was going to say, if you have a nice free flowing exhaust wheel, if the pressure ratios are right, you can omit the "FI."
Old Jun 30, 2007 | 12:43 PM
morgan@synapse motorsport's Avatar
ive had great luck with my gsr cams. i think i will be trying out a few different cams soon though.
chb93
Jul 2, 2009 08:28 AM
Integra414vteC
Dec 16, 2006 01:25 PM
X2BOARD
Sep 16, 2004 11:06 AM
Turbo R
Mar 4, 2003 03:15 PM
