timing belt
Old Nov 20, 2012 | 07:26 AM
g84's Avatar
g84
Default timing belt
My bad if this question has already been asked. I'm going to purchase a water pump + timing belt for my '98 honda accord dx auto (167,000km). I was told there are two kinds of timing belts: one is for the balance shaft and the other is crankshaft. Which one do I need?
thanks,
Old Nov 20, 2012 | 07:33 AM
Steve@Spreen's Avatar
Default Re: timing belt
Both....Also replace the cam, crank and balance shaft seals (and balance shaft seal retainer if not already equipped with one) while your doing this. Check the two tensioners/springs to make sure they are still in good condition. No use doing this job twice.
Old Nov 20, 2012 | 07:48 AM
g84's Avatar
g84
Thanks for your help
Old Nov 20, 2012 | 08:13 AM
Fred Demara's Avatar
This is a pretty easy job...I purchased "Eric the Car Guys" video on how to do it (I think I paid 12 bucks) and I would highly recommend it.
My balance shaft was out of time (and it was very noticeable)...Eric kinda "eyeballs" how to set the balance shaft..this is how I did it (now the engine is very smooth):
If you cruise youtube, you can see alotta videos on how the belt job is done....again, Eric's was very useful and worth it (in my opinion)...he has a few tricks and tips that helped.
Good Luck!
MJDT
Mar 9, 2014 09:17 AM
forevermemorabl
16
Sep 20, 2013 07:49 PM
ashb82
Mar 18, 2010 04:04 PM
rasta420
Dec 21, 2008 09:52 PM
blue32
Jun 1, 2005 02:10 PM
