Fuel cutout?
Old Nov 15, 2012 | 04:04 PM
Jgreen94's Avatar
Default Fuel cutout?
Hey h-t I'm having some major issues with my car.
It doesn't like light acceleration or coasting when I go to press the gas there's just nothing and then it kicks back in under 3/4 or more throttle, when I press the clutch in while holding the gas down it'll go back down to idle and then bounce up to where im holding the pedal at in neutral. The coolant gauge goes all the way down.
I replaced the coolant temp sensor and no fix, swapped fuel pumps with my other civic and am having the same problems. I'm at a lose as to what it is. No check engine lights or anything unusual. Clutch is newer it's a stock 97 dx sedan 5 speed. Any help would be greatly appreciated. Thanks
Old Nov 15, 2012 | 09:07 PM
jbpnoman's Avatar
Default Re: Fuel cutout?
Have you checked your timing yet?
Old Nov 16, 2012 | 02:35 AM
Jgreen94's Avatar
I haven't yet. It's at complete random so I didn't think it was an idea. It'll run fine sometimes. I'm still getting 33mpg
Old Nov 16, 2012 | 02:46 AM
jbpnoman's Avatar
Timing is easy to check, and doesn't hurt. Also, check your coolant level and thermostat.
Old Nov 18, 2012 | 04:43 AM
Jgreen94's Avatar
I don't have a light but I checked the coolant and replaced the thermostat. No better. Tps maybe?
Old Nov 18, 2012 | 04:50 AM
jbpnoman's Avatar
You can borrow/buy/rent a light. Also, check your fuel pressure. The tool you'll need to do that can also be bought/borrowed/rented.
Old Nov 18, 2012 | 04:53 AM
Jgreen94's Avatar
Where is the valve to put the tool on? My friend told me to check it but I have no idea where it is. I searched online but came up with nothing
Old Nov 18, 2012 | 07:38 AM
jbpnoman's Avatar
You should probably get your hands on a Factory Service Manual. The procedure for checking fuel pressure is well described.
There isn't a valve. You attach the fuel pressure testing tool at the top of the fuel filter, replacing the banjo bolt that is there.
bikersquid
Honda Civic (2001 - 2005)
Jan 3, 2018 01:37 PM
BaSikMuSic
16
Feb 27, 2012 08:38 PM
champLSinteg
Aug 28, 2009 08:42 PM
thermostate82
Oct 28, 2008 10:30 PM
H22CIVIC
Aug 10, 2001 06:15 AM
