Detonation Problems
Old Aug 6, 2001 | 09:46 AM
H22CIVIC's Avatar
New User
Default Detonation Problems
I cant figure out what is going on. My timing is retarded 2-3 degrees from stock. I am running 94 octane fuel!! Changed the plugs just to make sure of there heat range. By the way, I am running a 94 H22A motor. Also, I find my car detonates more as it gets hotter!! Please help. I dont want to leave it like this for long!!!!
Old Aug 6, 2001 | 11:34 AM
Vision Lude's Avatar
New User
Default Re: Detonation Problems (H22CIVIC)
What exactly does detonate mean??
Old Aug 6, 2001 | 04:01 PM
G's Avatar
G
You might want to check your coolant temps (not with the factory gauge), everything coolant/cooling related. After you are sure the thermostat works and the engine is running cool, fans are spinning the right way, check your fuel pressures, try running your car a bit rich to see if it helps anything (give your TPS a voltage of .5-.6 at the closed position). If the timing, cam timing is right on, it is a fuel or overheating problem......HTH
Old Aug 6, 2001 | 06:52 PM
H22CIVIC's Avatar
New User
Default Re: Detonation Problems (G)
Thanks. I will check my coolant temps. It gets worse as my car heats up so, maybe....... I've tried running extra fuel to no help. Throttle position sensor reads .52 volts. I dont want to change this as obviously this is not the problem. My cam timing is dead on!! I have had several different tanks of fuel in my car so it cant be that. My timing is right. Going to double check that though. It must be overheating!!!
Old Aug 7, 2001 | 05:04 PM
G's Avatar
G
Do you have an AF meter? Well, check the temp sensor, remove it and clean it if you have spare time, clean the fan switch also, it should be near the temp sensor, go through a helms and check the temp sensor if it is working properly, be sure the fans are running.........
Old Aug 8, 2001 | 09:11 AM
atomx's Avatar
New User
Default Re: Detonation Problems (Vision Lude)
Simply put ,...... detonation is when your combustion chamber gets to hot and explodes the fuel before the spark does. If you know anything about engines, you can only imagine what this would do to one.
Old Aug 8, 2001 | 12:38 PM
G's Avatar
G
Default Re: Detonation Problems (atomx)
And this is in reference to whose post, atomx?
Old Aug 8, 2001 | 01:31 PM
atomx's Avatar
New User
Well........you see your little name at the top of this box? (Re:Detonation Problems (G) ) If you look at my post about detonation you'll see who IT was posted too. I know it takes some time on how to figure out how to do the post'in thing but you'll soon get the hang of it.............he..he..he..heeeeeeee
Old Aug 10, 2001 | 06:15 AM
atomx's Avatar
New User
OOOPPS!..........I'm sorry , I didn't mean to bring this to the top again!
Jgreen94
Nov 18, 2012 07:38 AM
DawgC2
Mar 10, 2012 12:11 PM
wagonis
May 12, 2005 05:59 PM
swrdply400mrelay
Apr 15, 2003 09:40 PM
khang77642
Jun 10, 2002 12:16 AM
