Transmission & Drivetrain Gearboxes, Differentials, Clutches
clutch or syncro problem???
Old Nov 15, 2012 | 01:07 PM
keiserbikes's Avatar
Default clutch or syncro problem???
okay so i have an 06 rsx typeS the trans mission keeps grinding in every gear even if the clutch is to the floor i have to rev-match every up shift perfect and still get locked out sometimes the clutch grabs kinda low still and the clutch fluid is fine. any ideas on what could be the issue?
Old Nov 15, 2012 | 02:38 PM
metaphor51's Avatar
be water, my friend
Default Re: clutch or syncro problem???
Sounds more like a clutch issue. What kind of clutch/flywheel do you have?
Old Nov 15, 2012 | 10:47 PM
quierotacob16b's Avatar
i have the same prob. under normal driving condition there is no grinding as sone as i get on it i get grinds in every gear i have adjusted the pedal check fluids. i have stage 3 cc clutch on my s4c! some one help before i spend the big $$$$
Old Nov 18, 2012 | 03:54 PM
ThE HeLLRaZoR's Avatar
Is this while driving or while not moving?
Old Nov 19, 2012 | 07:26 AM
Axatax's Avatar
This is almost certainly a hydraulic/pedal adjustment problem, and you should fix this before you do further damage to your transmission.
I would just replace the CMC, slave cylinder, bleed the system and do a clutch pedal adjustment.
You can do this now, or add the cost of the above to your transmission rebuild when you destroy it by operating it in this fashion. Either way, you're doing this ^, so might as well do it now.
Figure $160 now, or $1000+ later.
sheBangZ
Oct 16, 2007 05:04 PM
hatchsi0485
Nov 21, 2005 06:13 AM
scrubachu
Jul 11, 2005 08:49 AM
onyx00
Dec 11, 2004 02:56 PM
jdmteg95
Dec 17, 2002 03:52 AM
