Hate electric problems, no spark
95 LS
I have no multi meter so =(.
Took cyln#1 wire out & put a spark plug in it, tried starting it, no spark. Tested for power at yel/blk wires at ECU, good there. Tested for power at yel/blk wire outside of distributor, also good. Inside the dizzy at the coil test light lit up at + & - ? Not sure if this means the coil is toast or what?
Forgot to mention, new plugs and wires a week ago. Also swaped out coil(used) because the car kept acting like it was losing all power for a fraction of a second while going down the road. Happened once since new old coil. Started it in the morning (below freezing) ran for about 2 min (warming up) and turned itself off. Can smell unburnt fuel coming from the tail pipe. Turn over but no start since.
Tach is does not move at all.
Again, no multi meter, only have a test light. Need to buy one
Ohh well, setting a cab up for tomorrow morning.
gl89
Jan 17, 2019 08:57 AM
