Honda is burning up too much oil!!!!
Old Nov 14, 2012 | 07:06 AM
gabriel0830's Avatar
Icon6 Honda is burning up too much oil!!!!
I have a 94 honda civic lx sedan automatic, engine has about 90-100k engine swap runnning on a D16, it is currently burning alot of oil, any suggestions or advice on what it mite be.
Old Nov 14, 2012 | 07:21 AM
EG FTW's Avatar
Default Re: Honda is burning up too much oil!!!!
is there grey smoke coming out of your tailpipe?
Old Nov 14, 2012 | 07:33 AM
jbpnoman's Avatar
You need to start with a leakdown test, to figure out how the oil is getting into the combustion chamber.
Old Nov 14, 2012 | 11:26 AM
Book1483's Avatar
Quick test with out any tools, best to have people help you so they can observe while you drive.
Hard acceleration (3-5 krpm), look for bluish smoke. Bluish smoke is the indicator oil is being burn. If you see it here, it's a piston ring/cylinder wall problem.
Hard decelerate, immediate let go of your gas after the hard acc. If you see the tint of blue smoke then it's a valve seal problem.
If you have proper equipment, Leak down test is the best way to go.
Old Nov 14, 2012 | 08:02 PM
KCHC's Avatar
how often you change ur oil and oil filter?? could be that piston rings are not making a good seal, if you never change the oil. just saying, that would be easiest fix. if not, your looking into spending some money.
Old Nov 16, 2012 | 06:10 AM
hondalx97's Avatar
if he has a comp tester you can test it too, check the compression dry then squirt oil into the cylinders, if the comp goes up its rings if it stays the same its prob in the head
Old Nov 16, 2012 | 03:18 PM
dirty19's Avatar
Ridin Dirty in Cali
rings or seals either way you need to do the right thing and rebuild it.
I dont believe in re ringing, or re sealing the valves.
Thats like putting a band aid on it.
Old Nov 19, 2012 | 07:32 AM
i recently changed the oil and white gray smoke comes out the back when i accelarate and also a lil oil comes out as well.
Old Nov 19, 2012 | 08:13 AM
AC/DC's Avatar
white gray smoke and your head gasket is damaged. its burning water
Old Nov 19, 2012 | 08:18 AM
stefanososodef's Avatar
if its chocking on idle and it burns oil then you have a pcv valve problem, simple and cheap fix... if not hopefully you haven't busted a seal... *cross your fingers*
Chris dc2
May 2, 2019 01:00 PM
motegicivic
17
Dec 3, 2011 11:47 PM
serjey15
Dec 4, 2010 07:20 PM
riS.I.R
11
Apr 2, 2009 06:15 PM
Jeff
Apr 30, 2005 04:01 PM
