Fuel Injectors flooding engine
Old Nov 14, 2012 | 05:56 AM
CodyGt3076r's Avatar
Default Fuel Injectors flooding engine
I am having trouble with my injectors flooding my engine. It will not stay running. It will only crank for a few seconds then die and the plugs are soaked. I checked for injector pulse and there is not any from what i can tell by using my test light.
If i unplug the fuel pump it will run which i dont understand how that is possible. Does anyone know whats going on or what i can do to diag the problem. I dont get it. Is my ecu lost its tune. If a s300. It sit for about 6 months on a shelve. Can someone give me some help. Thanks
Old Nov 14, 2012 | 07:37 AM
jbpnoman's Avatar
Default Re: Fuel Injectors flooding engine
Get a fuel pressure testing gauge. Attach it to your fuel filter, following the service manual procedure. Turn your key to ON(II). What does the pressure gauge read? Turn the key back off. Does it hold that pressure for a minimum of 2 hours?
Old Nov 14, 2012 | 10:28 AM
Ok here is the deal I dont have the stock filter housing and i have a braided line with aftermarket filter on it. It ran perfect before i swapped into my hb using a 1999 ex harness on my b16a2 engine. Before i was using stock b16a2 99 si harness because that was a 1999 si i owned. I am using hondata s300 on my setup also
Old Nov 14, 2012 | 10:30 AM
I really dont understand how the car can stay running if i plug the fuel pump up enough to prime it and then only if i unplug it then it will run at idle for a few minutes without the pump hooked up. How is that even possible
hondapowerb16a2
Mar 20, 2010 01:15 AM
JMD
Apr 11, 2005 04:05 PM
se93
Dec 25, 2003 02:03 PM
rschoener
Aug 26, 2002 01:12 PM
TurbodCX
Feb 6, 2002 06:59 AM
