obd2a y8 head with obd2b I/M and ECU?
i bought a 99 hatch with a d16y5 block y8 head and y7 intake manifold. it has been running with out vtec hooked up on the stock dx ecu. i have an obd2b y8 intake mani, and obd2b 5speed y8 ecu. (p2p)
ive been planning on swapping the intake mani and doing the iacv fix but i just found out that the y8 head that is on the block is obd2a not 2b. i assume i will need to plug the air injection holes in my manifold but will it still run right being on an obd2b ecu?
also any clarification on d16y5 (hx civics) whether or not they have a knock sensor would be appreciated.
The obd2b ecu will be fine. The CVT Y5s had the knock sensor so you'll just have to look on the back of the block to see if yours does or not.
greenman94
10
Feb 23, 2013 03:04 PM
EJ8 944
10
Jan 27, 2007 03:51 PM
joker4096
Jan 23, 2006 08:30 AM
