Limp Mode? Bogs at full throttle - B16A2
Old Nov 13, 2012 | 10:19 AM
Topsykrets's Avatar
Default Limp Mode? Bogs at full throttle - B16A2
Have searched and found common problems but no solutions. It's a 99 SI B16A2. The timing belt once busted and was replaced. Ever since then the car has been acting up not being able to hit Vtec or rev higher than 4000 rpm.
Here's what I've checked/tried:
TPS/MAP plug positions (They aren't reversed)
Plugs, Wires, External Coil, Cap
New Distributor.
Upgraded Fuel pump to Walbro 255
New Fuel Filter
New Stock Injectors
New Throttle body gasket
Cleaned the IAC Valve
Engine/Ignition Timing (all good here as well)
Fuel level at 42 PSI
swapped ECUs with no change. (Both chipped P28 and stock P2T)
Probably forgetting something... what else should i look for? Ive checked these things many times. The car ran fine before the timing belt busted.
Still runs fine other than WoT probably about 90% throttle and up it runs as if I'm out of gas or a plug wire is disconnected.
Thanks in advance.
Old Nov 13, 2012 | 10:28 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: Limp Mode? Bogs at full throttle - B16A2
What did they repair when they replaced the timing belt (valves, etc)? How does it run at idle? Check cam timing?
Old Nov 13, 2012 | 10:48 AM
Topsykrets's Avatar
The timing belt was the only thing that was repaired, nothing else was touched. Cam timing is at Top Dead Center. At idle, the car can rev up high but once the car is moving, it does not go past 4K rpms.
Old Nov 13, 2012 | 11:07 AM
Technical Hero
You didn't check for bent valves? uhhhhh.....
Old Nov 14, 2012 | 06:14 AM
Topsykrets's Avatar
Did not check the valves
Old Nov 14, 2012 | 11:18 AM
hybridmiklo's Avatar
truthfully it sounds like timing is off. possible valve issues, but mainly engine timing is off.
Old Nov 14, 2012 | 11:34 AM
Technical Hero
Ditto, triple check cam timing and if you still have the issue do a leak down compression test.
Old Nov 15, 2012 | 10:13 AM
Topsykrets's Avatar
Awesome, will try that and return back with some feed back. Thank you
Old Nov 17, 2012 | 11:16 PM
holmesnmanny's Avatar
Whoever replaced your timing belt before checking for damage has no business in the automotive business.
punchodex
19
Jan 3, 2015 03:52 PM
toolboxtony
Jul 18, 2011 03:23 PM
pimpwagon
Nov 12, 2010 08:41 AM
nkhd
Apr 3, 2009 07:23 PM
GsrTurboCRX88
May 18, 2007 10:15 PM
