Endless thermostat housing leak.
Old Nov 12, 2012 | 08:29 PM
danny9447537's Avatar
Default Endless thermostat housing leak.
Hello everyone,
So here's my problem, I have a coolant leak right under the thermostat housing and no matter what I do, it leaks. The leak isn't spewing too much liquid, but good enough to where I feel moisture under the bottom of the housing. I've replaced almost everything that has to do with the radiator (all hoses, entire thermostat housing chamber, thermostat, gasket, radiator, radiator cap, and reservoir tank). I didn't over tighten the bolts nor did I add any RTV sealant since that seems to do nothing. Any suggestions?
Thanks for reading!
Old Nov 12, 2012 | 10:34 PM
holmesnmanny's Avatar
Default Re: Endless thermostat housing leak.
Theres an o-ring that sits at the top of the water pipe that the thrrmostat housing sits on. Yours is probably bad.
Old Nov 13, 2012 | 01:55 PM
jdowen2's Avatar
Make sure your housing doesn't have a hairline crack in it. I had that problem.
alvinahmed
Sep 16, 2012 09:32 AM
moncherris_em1
Honda Civic (2001 - 2005)
Mar 28, 2011 05:37 AM
rebuiltSI
Jun 10, 2007 03:47 PM
fms1day
May 24, 2007 02:46 PM
hatchback
Apr 21, 2003 01:14 AM
