Help with 93 Honda Civic - no start issue
Old Nov 12, 2012 | 02:04 PM
sconnors11's Avatar
Default Help with 93 Honda Civic - no start issue
I have a 93 honda civic lx. the other day it died on me. I changed the fuel pump, the main relay and the ACG (s) fuse. Car still won't start up. Can anyone tell me what am i missing and what should I do to get the car running again.
Old Nov 12, 2012 | 02:26 PM
Fliptard's Avatar
Default Re: Help with Honda Civic
first, use google to search exactly what your looking for with different key words, It's like doing homework.
second, make sure you have spark, check timing, if you don't know how to do these, google it. Post back after you have checked these and we will go from there.
Old Nov 12, 2012 | 04:01 PM
Lizardslap's Avatar
here this should help you narrow it down
http://www.ifitjams.com/starting.htm
Old Nov 12, 2012 | 10:37 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Default Re: Help with 93 Honda Civic - no start issue
Title edited to be more descriptive. OP: Please read the rules and guidelines in this thread before posting.
Old Nov 13, 2012 | 10:36 AM
ThatOne02Accord's Avatar
First check the fuses under the hood and under the dash.
I had a the same problem, and checked everything and when I looked of the fuses under the dash fuse #24 was blown and was my problem.
Old Nov 13, 2012 | 10:50 AM
djakob's Avatar
Things i'd check:
1st) Coil
2nd) Spark plugs
3rd) Plug Wires
4th) Cap & Rotor
Old Nov 13, 2012 | 11:01 AM
Book1483's Avatar
Is your engine turning?
If your engine doesn't turn, problems with starter or battery.
If your engine turns, it's mostly likely a no spark or no fuel condition.
You've checked and replaced a few components. Can you verify that you are getting spark and fuel? If your engine is turning and you have fuel and spark, most likely your timing belt snap.
Good luck
Pop in a can
Apr 20, 2017 06:03 PM
ZachWood
33
Feb 22, 2015 02:34 PM
Kurtevensen
May 5, 2011 11:09 AM
coasttime
Jul 22, 2009 04:37 AM
hawaiian_ej1
Jan 5, 2005 11:59 AM
