No speedo an no cluster lights
Old Nov 11, 2012 | 10:53 AM
crewcut1983's Avatar
Default No speedo an no cluster lights
Been at this issue for MONTHS, replaced vss, put in new instrument cluster,replaced fuse 15 (was blown), did the TSB work on removing manifold bracket and checking for frayed wires (weren't any, but protected them per tsb anyway)... Still no speedo and no instrument lights..tried jumping the dimmer switch too, when I did that it does illuminate the gear selector lights but nothing else...any help would be great.it's my daughters first car and she needs a speedo and lights!
11/16 now the gas gauge is bouncing around, and then going back to empty even if not empty...all these gauge and light issues must be related?
Old Nov 11, 2012 | 05:49 PM
ekn00b96's Avatar
Default Re: No speedo an no cluster lights
i would trace all wires to see if somethings grounded bad. wires are crossed. something of the sort.
Old Nov 11, 2012 | 05:50 PM
ekn00b96's Avatar
have you blown multiple fuses?
Old Nov 14, 2012 | 06:29 AM
Thanks for reply..Wish I could get some help on this common problem...No other blown fuses....So far the new fuse # 15 hasnt blown..Im outta ideas other than tracing wires one by one, but really no clue where to begin if I do that... I had really hoped to find a cooked wire under the manifold bracket!
Ryan559
Sep 6, 2013 02:39 PM
Auby
Jun 22, 2008 02:14 PM
Coupe-R
May 24, 2006 03:41 AM
hYbRiD EeEkAy
13
Jul 16, 2004 02:57 PM
vtNaMeSe
Jun 29, 2003 10:32 AM
