Transmission & Drivetrain Gearboxes, Differentials, Clutches
LSD Speed sensor with plates clutch differ?
Old Nov 11, 2012 | 05:03 AM
maxogsr's Avatar
Default LSD Speed sensor with plates clutch differ?
I found this video while searching for other stuff and was wondering if some Kaaz user had some issues with there speed sensor?
Old Nov 11, 2012 | 07:49 AM
Honda Bull's Avatar
Default Re: LSD Speed sensor with plates clutch differ?
What seems to be the problem exactly that you're asking about?
The gear is different to accomodate the design characteristics of the plate LSD housings (the speed gear is often machined into these and is a larger diameter). Because of the larger diameter, the diameter of the speed gear shaft for the sensor must be reduce (like in the video shown). The companies supply that part to install.
The gear teeth are designed to spin at the same RPM as the OEM speed gear setups so that the readout to the ECU does not change.
trincivic
Aug 6, 2011 04:59 PM
88 EF Hatch
Feb 24, 2011 07:58 AM
n1_egsex
Sep 3, 2007 12:10 PM
n1_egsex
Aug 29, 2007 02:44 AM
JDMINTEGRALS
Feb 19, 2006 03:58 PM
