How to tell TDC on b16a2?
Old Nov 10, 2012 | 04:35 PM
WhiteOnRice's Avatar
Default How to tell TDC on b16a2?
I think I jumped a tooth while trying to adjust the tension, I want to mark sure it's all set before starting the car. I can get pics if needed.
My problem is my crank pulley does not have any white paint on it and the cam sprockets only have the UP mark (no inner markings to tell when they are positioned correctly to each other). Instead of white, the crank has 3 hash marks about 1.5mm apart from each other and a 4th has mark about 15mm from the 3.
Also, I fortunately marked the belt and sprockets just in case but they were not lined up at the time of the belt slip, how many cycles will it take until they line up again?
Old Nov 10, 2012 | 05:08 PM
CO671's Avatar
Default Re: How to tell TDC on b16a2?
Try taking out #1 spark plug and getting the piston to its highest point?
#1 cylinder/piston/spark plug is always the one closest to the camgear.
Old Nov 10, 2012 | 05:14 PM
Former User's Avatar
Old Nov 10, 2012 | 05:32 PM
Originally Posted by RonJ@HT
Old Nov 10, 2012 | 05:43 PM
This^
Old Nov 11, 2012 | 06:38 AM
Is it TDC every time #1 is at its highest point? I thought it took a few cycles to be at true TDC. At least that's the way I have to get our Subies TDC.
Old Nov 11, 2012 | 06:49 AM
Bix VT's Avatar
The one off by itself is the TDC mark. The other three are various degrees of advance.
Old Nov 11, 2012 | 06:54 AM
Thanks!
92db2gs-r
Apr 4, 2011 11:57 PM
TheCrimsonGhost666
Aug 21, 2010 09:49 PM
tibs
Jun 12, 2005 01:56 PM
JohnnyEF
21
Jun 8, 2003 04:41 PM
IN VTEC
Oct 2, 2002 11:37 AM
