Need oil cooler bolt size ????
I have a 2000 gsr block and I need to find the correct oil cooler bolt size for it . ( IM NOT RUNNING A OIL COOLER So I NEED THE SHORTER BOLT ) does anyone know the part number ?
You seek p/n 90015-PH1-013.
It is listed in the Oil pump - Oil strainer section on the parts sites.
http://www.hondapartsunlimited.com/p...p-oil-strainer
The torque should be 54 lb-ft like the ITR oil cooler bolt.
